dougrainer
Sep 16, 2014Nomad
Ducted means they ran part of the furnace ducting over the holding tank area(usually the fresh tank. Radiant means they ran a 12 volt heat pad on the bottom of each holding tank. If you have exposed Holding tanks, look at the bottom of each tank and see if there is a flat pad with 2 wires glued to the bottom of each tank. There should be a 12 volt switch inside the bathroom area labeled Tank Heater. Usually lighted red in color. Doug
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
