bluka43's avatar
bluka43
Dump Valve Lubricant
I've recently replaced the slide valve seals on the black water tank. check for leaks and none seen. The valve seems to be a little harder to operate when no liquid is in the tank. I don't believe the bolts are too tight, because it worked fairly freely when I first put it back together. I'm thinking that I need to use a valve seal lubricant at this point. Any suggestions as to what to purchase to use?
Thanks
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: Oct 05, 2025
