dougrainer
Mar 25, 2018Nomad
ALL 5 button boards are the same. ALL 10 button boards are the same. The difference is very obvious, so you should be able to tell. Also, you are assuming the COM cable from Zone 2 to Zone 1 is wired correctly on the modular plug from the factory. Have you verified the Wire alignment for the plugs? Doug
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
