dougrainer
Jul 04, 2017Nomad
The Boards 3 amp fuse has NOTHING to do with the 120 operation of the fan or the compressor. It is a 12 VOLT protection. That means there is something on the BOARD or the tstat wiring that is blowing the fuse. I would pull the Tstat and check the Wire Bundle and tghen check the wiring at the upper control box. I cannot remember when I ever had a problem with the Board 3 amp fuse blowing. Usually if you have a short, it is pretty obvious. Also, if the 3 amp fuse blows, does the COMPRESSOR stay ON? Doug
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
