dougrainer
Feb 15, 2015Nomad
robatthelake wrote:
The Telco connectors in the Roof mounted Air Conditioners are problematic and are a bit difficult to change. Download a trouble shooting chart from Chris Bryant on the net! The connectors are available from various on line sources . There are several styles Tyco is one supplier!
Also there are two In line Fuses located under the refrigerator on top of the Furnace that may have blown.
Make sure that the Blower Switch located in the Water Bay is in the Off position as they also have an occasional problem which will blow the fuse!
Those fuses have nothing to do with power to the CCC system. The 4 wire connectors are just Telephone ends. Very easy to change. Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
