wa8yxm
Dec 18, 2018Explorer III
One of the campgrounds I stay at in the winter has Heat Pumps for the office/internet lounge/Bath-Rest rooms and laundry. They ice up when running in HEAT mode (outside coils) and then when done heating reverse long enough to melt the ice.
I suspect an installation error. (Frost sensor misplaced) but.. Can not guarantee Make sure the coils are clean.. check the owner's install manual(s) to insure it is properly installed including any frost sensors. then call for warranty repair/advice if needed.
NOTE: heat pumps are NOT designed to be used below a set temp. like (but not necessarly) 40 degrees. F
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
