dougrainer
Dec 18, 2018Nomad
One thing. The CONDENSOR fins MUST be clean. If you have NOT cleaned them, then the dirt/debris will hold the moisture on the fins and they will ice up faster. The 10 button CCC and the 5 button CCC boards have different red plastic 2 wire connectors. They will not interchange. 24 inch would be for a Penguin model with on board control board. 48 inch would be for evap area control board mounting. All 5 button CCC boards use the same design ambient sensor. 24 or 48 will work. Doug
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
