otrfun
Mar 23, 2014Explorer II
720Deere wrote:In your DIY attempt, are you saying you inserted some kind of insert into the middle of the OEM cap with the fuel hose attached--similar to the Duration? If so, where did you purchase the inserts? Did you have problems with an air leak (i.e., insufficient fuel flow)? Thanks.
I haven't used the Duration kit, but I originally did a DIY kit much the same way. I was never really happy with it so I bought the aluminum caps. The quick connects and aluminum caps are pretty hard to beat and they allow for you to maintain a good seal with your OEM caps for travelling.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
