otrfun
Mar 23, 2014Explorer II
Devocamper wrote:I'm assuming what you're describing is very similar to those being sold on eBay with an elbow or straight barb installed on an OEM Honda gas cap. Did you use one of those 5/16" or 3/8" brass fittings similar to those sold at Lowes or Home Depot?
You will still need a extra set of caps for each Honda generator, you have to remove the shut off to install a barb fitting in the cap, I have a two generator setup for my tank and use the original caps with the shut offs for travel.
What kind of gas container are you using?
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
