There is one hole in each bolt and 2 on the EZ Flex. If you decide to change, grease the Zerk before installing to ensure the hole was drilled all the way through. Bolts are serrated and not designed to be turned. You have to drive them out. Remove Zerk before trying to drive the, in. I tightened the nut slightly before each hit and the bolts went in easier.
