diazr2
Mar 22, 2015Explorer
E-Z Flex ?
I am thinking about installing these on my fifth wheel does anyone out there have these in use, and if so what do you think of them.
Lynnmor wrote:
Don't put a groove in the bolt. That would create a stress point and a possible fracture. Instead, cut a figure 8 inside the bushing using a lathe or by hand using a Dremel type tool. It doesn't have to be real deep or pretty. Without a place to go, the hole in the bolt may be blocked and no grease will flow in. Some say to orient the hole on the side opposite the load but that wouldn't supply grease to where it's needed.
