Yes-as post above you said there are two movable parts. Should have grease fitting in the top. If no fittings, rub your finger on the top and there should be threaded holes. If it has no holes for the Zerks, then I would say that you have a defective set.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
