diazr2
Mar 22, 2015Explorer
E-Z Flex ?
I am thinking about installing these on my fifth wheel does anyone out there have these in use, and if so what do you think of them.
BFL13 wrote:You're mixing the message: yes, the metal bushings are much sturdier than the plastic ones. However, the "shackles" (links) are heavier so that they don't rip apart like the el cheapo ones installed by manufacturers. The holes on the OEM ones will keep elongating until the metal tears.
I did get that the shackles are heavier-built so won't wear through their metal vs plastic bushing holes as badly.
