phemensExplorerOct 17, 2018E-Z lube hub cover replacement?I have E-Z lube hubs, but the wheels have chrome hub covers that insert from the inside, which means that if I want to grease the hubs, I need to remove the tires. Has anyone replaced those hub cover ...Show More
ralphnjoannExplorerOct 17, 2018You can purchase the hub covers at etrailer:eTrailerAmazon sells replacement rubber plugs:Amazon
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
Related ContentReplacing Emergency Exit CoverReplacement Lights for TTLight cover replacementJack LubeToilet seal lube?
