allen8106
Oct 17, 2018Explorer
I have easy lubes also and there's a center cap on the hub cap that should pop out and then you remove the rubber plug to grease them. Don't use an air powered grease gun, use a manual one.
You need to make sure you jack the wheel off the ground and turn the wheel while injecting the grease.
