Trying to find out an accurate capacity for my 1996 Ford E4OD transmission. I have seen anywhere from 16.2 to 19 Qts. I had to replace my radiator and didn't like the look of the transmission fl...
You've gotten the best answer I could help with already. so... Does it have a Banks Transcommand? If not consider getting one. The largest fault the E4OD had was the soft shift they designed into it. That means that under heavy load (ie towing) the transmission can overheat. The Transcommand adjusts this shift and lowers the transmission failure rate.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
