1L243's avatar
1L243
Explorer II
Jul 20, 2022
Easy Start By Micro Air
I wanted to run my 13.5 Dometic AC on my generator but having only a 2000 watt Honda EUI, it was either buy a bigger generator or try the Easy Start from Micro Air.
I decided to go with the Easy Start. Installation was straight forward a youtube video was a great help.
After installation you have to go though a learning process for the Easy Start.
After the learning process I connected to my Honda 2000 and it ran the AC just fine. Prior to the Easy Start it would just trip the generator.
I tested amps at sartup prior to Easy start and it was around 32 amps. Now keep in mind this is just for a second when the compressor kicks on but enough to kick off the generator.
After Easy Start the start up amps are around 15 to 18 amps. It's so fast it's hard for the electrical monitor to record it.
The Honda has to be run on fast or run mode and not econo mode when using the AC .
For fun I thought I would see if the AC would run on my 2000 watt inverter and it did!
It was no different than running on the generator as far as the start up is concerned. Once the compressor kicks in the AC is running on about 12 amps.
I have a 500 watt solar system with 2000 watt Renogy inverter. My battery bank is 340 amp hours of lead acid.
I know I can't run the AC long on the battery bank that I now have but it will be interesting to see what happens when I'm dry camping in two weeks and see what the draw is on ac when solar is at it's peak of about 25 amps.
When ever I run a big appliance like microwave or coffee maker off my lead acid batteries my battery voltage drops to about 11.5 volts and it stays there until they appliance is turned off. Then the voltage creeps back up to the actual voltage. I understand this does not happen to Lithium batteries. It makes it difficult to monitor the battery voltage when under a heavy load.
So a big thumbs up to Easy Start by Micro Air
Having RV issues? Connect with others who have been in your shoes.24,298 PostsLatest Activity: Aug 09, 2025
