BFL13
Mar 07, 2014Explorer II
My Honda 3000 with eco off runs at so-called full blast, but then when I turn on a good load like my PowerMax 100a charger, the Honda grunts and seems to get a bit louder. How can that be if it is already at full?
Once I get the 100a going I turn eco on and the noise drops some. After amps taper, the noise drops even more, till it is the same as with no load (not much noise)
In eco, if you add a load (and the gen does not conk out!) the noise rises up to whatever and drops off again when load is reduced.
If you do want to run a big load in eco then let the gen warm up first or it will conk out. Easier to just start with eco off and then turn eco on afterwards.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
