MEXICOWANDERER's avatar
Mar 05, 2018
Egg Poaching And Energy Versus Ease Of Use
The last poacher I used was 120vac and it didn't take long before the eggs started sticking to the cups, even when heavily oiled.
I prefer electric because of 83F mornings. But the last poacher really draws down the AC ammeter. Borderline overload on the small inverter.
DC seems not to be an option
So that leaves stove top burner heating.
Being one foot is in the poorhouse and the other on a greased banana peel I sure could use some hints about getting a sensible egg poacher that avoids the almost immediate egg sticking problem.
Would appreciate hints
  • MEXICOWANDERER wrote:
    Boiling water with an egg cracked into it seems to allow most of the white to foam and get near impossible to recover.
    Not if it's a slow roiling boil with vinegar. Keep the boil slow while cooking the egg(s). Pull out with a slotted spoon. May take some experimentation. Not sure if water quality/hardness is important?
    Dunno why it works, never thought it would. But my daughter just showed me how a few months ago. An old dog can learn new tricks.
    But there's a lot of other good ideas here too. Will have to try the tin cup and and an inch of water in a fry pan methods, as well as the microwave.
  • Boiling water with an egg cracked into it seems to allow most of the white to foam and get near impossible to recover. My Samlex does not like +400 watts. The microwave is a no-go.
    The best answer in my case seems to be a stove top cooker with pockets that actually are easy release coating. I toast on an open burner with a fine stainless steel mesh.
    Thanks for the suggestions!
    EGGS BENEDICT
  • Gjac's avatar
    Gjac
    Explorer III
    I put about an in of water in a frying pan crack 5 eggs into the hot water then cover with a lid with heat on low. The lid helps cook the top of the eggs faster, and also used less energy and no electricity just propane.
  • JaxDad's avatar
    JaxDad
    Explorer III
    Use a tin cup with the burner on very low, it boils surprisingly fast, very little heat transferred to the room.
    It doesn’t get much cheaper than a tin cup either.
  • I got silicone rings from Walmart and cook eggs in the skillet. All you do is spray the rings with pam and add the egg. They come out just like the eggs at McDonald's egg muffins. Doesn't take too long. Found them in the aisle where silverware etc is.
  • “Being one foot is in the poorhouse and the other on a greased banana peel”
    Eat cereal......cheaper.
  • Almot's avatar
    Almot
    Explorer III
    Nothing is wrong with microwave, and takes only a minute. I bet there will be less heat released into your room than with simmering on stove.
  • Boiling water is a waste of energy. Just fry the eggs on a small non-stick pan, tightly covered under very low heat. Use an induction heater and compatible fry pan.
    Or if you insist upon poached eggs, boil a pot of water with a tablespoon of vinegar and carefully drop in the eggs when you have a medium boil. Keep it boiling and then use a slotted spoon to get them out. This actually works well for us. Again, induction heater and compatible pot if you don't want to use propane. EDIT: or maybe microwave as suggested above?
  • Go to Pintrist. If you have a microwave and large straight side mug your in business several recipes for this method. Also, when on pintrist just search poached eggs there are a lot of ways to do them.
