I have a heating element in my a/c and gas heat. If I turn on the elec. heat, will the system automatically switch to gas heat if the temperature drops below a certain degree?
Coleman HP the tstat setting controls HP versus Furnace. This is stated in the Coleman owners/operation manual. IF you try to set the HP Heat MORE than 5 degrees warmer than the interior temp, the furnace/Aux Heat source comes on and the HP is in standby until the interior temp is within that 5 degrees. Then the furnace shuts off and the HP comes on until set temp is reached. The HP can then keep the temp that is set. Doug
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
