path1's avatar
path1
elec help Please, elec dist box
(Spent lots of time searching here and couldn’t find what I needed)
I’ve been having way to many RV problems lately. Latest is my bedroom fantastic fan and fan in bathroom quit working. All fuses turned out to be good when I pulled and tested them. Trying to find the problem, eventually lead me back to where the fuses are located. The “power distribution” panel. I then put a volt meter across the actual metal spade connectors that the fuses plug into and found that I have one that is not making a connection. So in my limited elec knowledge I believe that circuit is not making a complete the circuit.
One part of me wants take this thing apart and just replace or fix the spade connection on this one wire. Other part of me thinks the spade connections are one large piece molded into the plastic. And of course no part of me wants to change out the whole wiring complex for one fuse.
In the pic with screw driver in it, the screw driver is pointing to a silver colored screw that I think holds this thing together. If you’ve taken one of these apart before any hints? Are spade connections molded into plastic? Or can each one be taken out and worked on? Can I undo the silver screw and remove the part that the fuses slide connection?
What is the real name of the part that all the spade connections slide into? Only thing I could think of is “fuse circuit board connectors”.
Thanks
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 19, 2025
