path1
Jun 02, 2016Explorer
Sam Spade wrote:Chris Bryant wrote:
Not to argue, but if the tow vehicle works fine, what is YOUR suggestion?
Up to this point, the OP hasn't really SAID if the failure is ONLY on the trailer or not. You assumed it was and I assumed not.
It's not an argument, it's an adult discussion.
In his last post, he seems to indicate that the failure is ONLY on the trailer......that is, the 4 way flashes correctly on the tow vehicle but not the trailer.....and if that's the case one would think there is a problem with the wiring going to the trailer somehow and odd problems like that DO tend to be ground related.
Odd problem indeed.
Op here...Yes, only on left rear signal light on trailer.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
