RJsfishin
Apr 12, 2014Explorer
Quote:
The drums are NOT balanced from the factory and there is little point in balancing wheels under this condition.
I have seen many drums w/ balance weights spot welded (fused) to the drums, and others that have been drilled.
And if the wheels are spun balanced on the vehicle (like they used to be) or the drum and wheel are balanced as an assembly off the vehicle, the entire assembly gets balanced. So there is a way around out of balance drums.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
