tsherv
Jun 11, 2019Explorer
I only put new shoes on one side. The other side had very little wear.
As far as the connections go: I use heat shrink "butt connectors". As far as I know I have a good connection?
I was told that when I installed the new brake assembly, that there isn't a positive and negative wire. The dealer told me that it doesn't matter which wire you connect. Just so both wires are hooked up. Does that make sense?
