Lynnmor
Jun 12, 2019Explorer II
tsherv wrote:
I think I'm on to something: I tested the voltage of the blue wire coming from my brake controller while pushing the manual override. It measured 12 volts (which it should). When I tested the brake pin of the 7 pin connector, it only registered about 3 volts. I tested the blue wire right before it went into the 7 pin connector, and it measured 12 volts. I'm thinking maybe the 7 pin connector on my truck is bad?
Sounds like you found it. Do check the other pins as well so you know that you have a good ground while checking with a voltmeter. Even with a bad connection, it is surprising that the reading is that low with no load.
Usually you should replace all brakes on an axle so they have the same effect. Yes, burnishing does take time and with only one side new, there will be quite a difference possibly pulling the trailer to one side. Don't believe those that discount the effect of burnishing, in recent years brake friction material has changed causing the poor performance when new.
