lotto38's avatar
lotto38
Electric Brake Issues on TT
I have a wheel on my TT that seems to be getting more "Juice" than the other three. I have my prodigy gain set at 6 and the boost at 1.(Same problem if no boost) In a short drive, the wheel will heat up more than the other three.It sometimes gets hot to the touch. I jacked it up and the wheel spins without any resistance. I have had two shops look at the wheel and they both say everything is OK. I am wondering if they check the voltage in each wheel. I don't believe that the Prodigy is to blame, because there is only one wire going to the plug. On gravel with the boost, the wheel will lock up.
Thanks.
