lotto38's avatar
lotto38
Electric Brake Issues on TT
I have a wheel on my TT that seems to be getting more "Juice" than the other three. I have my prodigy gain set at 6 and the boost at 1.(Same problem if no boost) In a short drive, the wheel will heat up more than the other three.It sometimes gets hot to the touch. I jacked it up and the wheel spins without any resistance. I have had two shops look at the wheel and they both say everything is OK. I am wondering if they check the voltage in each wheel. I don't believe that the Prodigy is to blame, because there is only one wire going to the plug. On gravel with the boost, the wheel will lock up.
Thanks.
  • You can't have 1 wheel getting more voltage period.
    It has to be mechanical problem, unless as suggested you have only this wheel hooked up to the electrical.
    I would take the trailer on low traffic road, drive for few miles without touching the brakes, than stop using E brake and check the wheel temperature.
  • Rvpapa wrote:
    Or maybe it is the only wheel actually doing all the brakeing.
    Art
    He will respond with " shop adjusted correctly :S
    Art
    Bingo!
  • Or maybe it is the only wheel actually doing all the brakeing.
    Art
  • Check voltage at each wheel...that simple. Doesn't even have to be lifted off ground. If you have a DC clamp ammeter helps as well
  • The shop that I used, I have been dealing with them for 15 years. A month ago, bearings were packed, three replaced and all four wheel were adjusted. I am thinking that one wheel is getting mroe amps than the other three.
  • x2 on adjusting shoes slack.
    I would lift the axle myself and also check it for bearings play.
    Shops are not looking for a job, where they will not make easy money on parts mark-up.
  • The problem is with one wheel only. They are adjusted correctly.
  • just adjust the pads on that wheel alittle looser than the others see if it continues. Or unhook the brakes to it see if its a diff problem.My opinion if its getting that tight with brakes it should be locking up
Having RV issues? Connect with others who have been in your shoes.24,321 PostsLatest Activity: Sep 21, 2025
