enblethen
Aug 19, 2013Nomad
Is your rig 30 or 50 ampere?
Rigs normally come with #10 wire for 30 amp and #6 for 50 amp.
Depends on what you are trying to operate.
30 amp with one AC unit, no water heater 120 volt element, you should be able to utilize the #10.
50 amp running two AC units, water heater on LP, you should be able to use the #6.
Building extension cords gets expensive when you start buying the connectors.
30 amp extension cords are cheaper off the shelf at Walmart.
50 amp are expensive no matter which way you go. Easy solution is to reduce load and use a 30 amp extension cord with dogfbone adpater.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
