dougrainer
Jul 11, 2015Nomad
Vulcan Rider wrote:kaydeejay wrote:
Most electricians do not know what a 30A RV receptacle is and think it should be wired the same as for a welder!
I don't know about the incidents that you quote but as this goes along farther it gets even more unbelievable.
The 30 Amp receptacle has 3 conductors, right ??
And a 220 receptacle has 4 conductors, right (hot, hot, neutral and ground) ??
If the "electrician" runs two hots (4 wires) to a 3 conductor receptacle.....where does he connect the 4th wire ??? Or which of the remaining two conductors does he connect to the one remaining lug ??
I can see a rank amateur screwing this up but not a real electrician.
The problem is "What is a real electrician". As a RV professional(36 years), I have made a good amount on money from so called licensed electricians miswiring both 30 and 50 amp RV plugs. Texas seems to have the weakest licensing for electricians. I get calls all the time from so called professional electricians asking ME how to wire a 30 or 50 amp plug. The miswire in Texas is an epidemic. I always tell the RV'er, IF the so called electrician has to call ME, then he is not a Professional Electrician with the knowledge to do the work. ANY licensed/bonded electrician should KNOW what a 30 or 50 amp RV service is and what is required for the installation. But, sadly, a LOT do not. Doug
