UV417's avatar
UV417
Electric Fuel Pump
I want to use an electric fuel pump to supply gasoline to a Honda EU3000i generator that was previously supplied by a tank mounted on top.
I am installing this generator in a small motorhome and want to use gasoline from the motorhome`s tank.
Can I use one of the universal electric gas pumps that have low psi rates? Can the generator operate with the low psi from the electric fuel pump where before it was gravity fed? I have removed the generator`s fuel tank.
Thanks John
  • I think you'll find that the Honda actually has a fuel pump (vac. operated) - or at least the eU2000's do.
  • It should work. Be sure the pump pressure is at or below 5 PSI
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
