Stewie_Griffin's avatar
Feb 23, 2023
Electric galley slide issues_Slim Rack_2018 Seismic 4212
**Edited the title to give more information and for accuracy**
Okay, so the wife and I purchased a 2018 Jayco Seismic 4212 last year and we noticed right off the bat that our galley slide seemed sluggish and possibly out of alignment.
Well, we used it a lot last year and after some time, it started really struggling to come in at first. Most times, it will come in an inch at a time for a bit, then eventually come in normally.
Now, this has tracks on the side (not a schwintek) and I noticed they had a sticky grease type lube on them. I washed them and put some dry lube on them. I also put grease on the bottom where the rollers are. No change.
Well, we bought a 5 year warranty with this RV and I checked it in with the dealer a month ago. They're telling me the interior gears and motor needs to be replaced. $5,000.00 and they doubt the warranty company will cover it. They asked me if I greased the gear rails, I told them I used that dry lube, but only after the slide was acting up.
I'm going to get the RV tomorrow, because they need the space and it's going to be a little bit before this gets figured out.
My question is, can the motor and gear wheels be saved? Can I get in there with some cleaning agents and clean the gear teeth enough to save everything, or is it a worthless cause?
I have no idea how I'm going to prove to the warranty company that the damage was done before we bought it.
At this point, I'm hesitant to do anything, I thought lubing the gear teeth was the right thing to do (metal gears usually need lube), but apparently that's not the case and I don't want to make a bad situation worse.
I wish there was a warning sticker there that stated to not use grease on the gear rails. They have warnings for everything else.
