MrWizard
Feb 12, 2019Moderator
Is that the same outlet, or same circuit breaker, that the heater is plugged into?
Put the meter on a different circuit, measure with heater off and heater on
And post the numbers here
If you have more than one
Make sure they are on different circuit breakers
A 50 amp service should have no problem with a pair of portable heaters
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
