rk911
Feb 12, 2019Explorer
BobnSofi wrote:
Hi All,
we are full timing and use and electric space heater. This causes a voltage drop (according to the cheap voltage meter plugged into a bathroom outlet).
The space we are in has 50amp, 30amp, and two 15amp. We are plugged into 50amp.
Of course, we do not want to hurt our RV.
So...
How do you all pros handle this perceived voltage drop occurring when using an electric space heater?
??? Is this an actual problem ???
Alternative suggestions of using the A/C heat pumps, or LP furnace are obvious, thus not needed.
!!! Thanks in Advance !!!
what was the voltage before and after running the heater. nominal voltage is 120 +/- 10% or 108-132 volts.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
