accsys
Sep 16, 2016Explorer
Dennis12 wrote:
Does anyone know of a electric heater with more than 1500 watts?
That's pulling about 13 amps and about the max that should be pulled through normal house/RV wiring with other things on the same circuit. Anything bigger could start blowing fuses and breakers if anything else is on the same fuse/breaker. If you had a dedicated circuit you might get away with something a little larger if you could find one.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
