pianotuna
Sep 18, 2016Nomad III
If you have an existing heater that is being run at a lower voltage, you can calculate the new wattage using the equation below:
Actual wattage = rated wattage X (applied voltage) squared / (rated voltage) squared.
Example
464 X (105 squared) / (120 squared) =~ 355 watts of actual wattage output.
I can see I'm going to want to use the autoformer for more than just the air conditioner.
Example
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
