snowpeke's avatar
snowpeke
Electric jack for 5 wheel goes up and not down
The jack stands that raises the front of the trailer up and down just goes up and not down. Worked fine in the morning next camp site won't go down. Checked the switch and it seems ok. Only 2 wires going to the motor. I tried jumping power to each one. One makes it going up the other it goes up very slow. Any ideas?
  • You have one switch but two motors? One for each leg? When you say the one doesn't go up, do you mean it won't retract, or it won't raise the trailer? Check to see if you have full voltage to the switch, and from the switch to each motor. Do the battery/ies have a good charge?
  • I think up/down is like in/out with the slide. The motor two wires change pos and neg to turn the other way as set by the switch contacts.
    I had that with the slide switch. New switch fixed that.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
