jamiet's avatar
jamiet
electric jack
I have a gulfstream innsbruk tt 28 ft weight is 6700 dry towed with 2004 chevy 1500 ex cab what size electric tongue jack would be the wright size for my tt
  • hddecker wrote:
    Terryallan wrote:
    3000lbs would be plenty. Doubt you will ever have a TT with a tongue weight of over 3000lbs. And if you ever do. You gonna need a new truck
    X2
    Opps hit the send button too soon.
    No matter what jack you choose make sure the shaft fits the hole in the A frame.
    There are two sizes of shafts, I found that out the hard way, bought a replacement in an emergency. Get back to trailer to install and find the shaft on the jack is smaller than the A frame hole. Made for a wobbly lift until I got home and put a spacer in to fill the gap.
    X2
  • 3000lbs would be plenty. Doubt you will ever have a TT with a tongue weight of over 3000lbs. And if you ever do. You gonna need a new truck
  • robsouth wrote:
    The Right size would be the largest one you can afford. You never know when you might want to transfer it to a larger trailer.
    Exactly!
    WoodGlue
  • The Right size would be the largest one you can afford. You never know when you might want to transfer it to a larger trailer.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
