Hi all just a quick question that I am sure someone out there will know the answer to. The electric jack on the TT stopped working yesterday for some unknown reason I was lowering the TT onto the ba...
Check the ground connection. Some jacks are grounded via the mounting bolts and serrated washers that bite into the metal. The light won't draw much current but with a bad ground, it won't supply the current needed by the motor.
Sometimes all you need to do is simply tighten up the bolts and I would try that first. Could also be a faulty mini circuit breaker supplying the jack.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
