wa8yxm
Nov 02, 2019Explorer III
Look at your distribution panel (Breaker box) it should be easy to figure out which breakers coospond to which main breaker (Right or left. or Top/Bottom depending on box) then you an figure out what they did. IF not sure turn off breakers that are busy (Example air conditioners or water heater)
NOTE one AC should be on one leg one on the other. The water heater is on one leg.. (if you have an inverter it should be on the other) and one AC + Water heater---25 amps easy .
