dougrainer
Nov 03, 2019Nomad
philh wrote:
Interesting... and makes me wonder if why one leg at my primary campground was way low on voltage. If everybody is pulling off of the same leg...
The "legs" are NOT always on the same PHASE. EACH leg is a separate Phase on 50 amp service. So, they could have a Transformer problem or such, and that would cause different readings on the legs. The CG plugs are not in line---site 1 then it daisychains to site 2 and so on. NO. EACH leg wire/s at Sites should go to a main supply breaker panel that is rated for the number of 50 amp sites. If the main panel has 20 sites to it, then there should be 40 wires with 2 wires each going to each 50 amp plug with the required SIZE Neutral supplying each 50 amp site plug. Doug
