rocmoc
Sep 13, 2013Explorer
Electric only working on Side 2 of inverter. FIXED!!!!
Same problem after installing a new inverter. Both sides of electrical works on pass-thu mode when hooked up to shore power. Switch over to invert and only side 2 works. This was the problem before installing a new inverter. Thought the old inverter was the problem as there was corrosion all thu the old inverter's boards & the electrical connections. The old inverter was tested at a local RV repair location and was told it was shot. I purchased a new (updated model) inverter (not from the repair location) and still have the same problem. HELP! Any ideas. Everything is great when hooked up to shore power but only side 2, Micro-wave & bathroom, works when not on shore power. Every outlet use to work!
Thanks,
rocmoc n AZ/Mexico
Thanks,
rocmoc n AZ/Mexico
