Curly2001
Dec 19, 2020Explorer II
Electric space heaters
Just curious if anyone has a good safe electric heater to use to heat a 30' fifth wheel overnight? Would like to supplement the propane furnace on colder nights.
Thanks,
Curly
Thanks,
Curly
theoldwizard1 wrote:pianotuna wrote:
The safest may be the oil filled units. Their surface temperature is lower.
These also put out a nice "comfortable" heat. A bit slow to warm up. If you have a 30A hook up, use two and skip the furnace. These are silent.
Also, heated mattress pads work much better than heated blankets,pianotuna wrote:
My favorite heat source is electric heated carpets.
Brand ?
Bert the Welder wrote:
I'm interested in what type of heater you guys are running that has heated/melted your extension cords? Or what gauge cords you're using?
As for the OP. I look at my best bet being on a "bigger" name in the game as being "safer". Though I have little more than faith in that thinking. Howell, Sunbeam, Noma, Panasonic. Dyson if you like paying triple for the Gucci factor.
Cummins12V98 wrote:
Gdetrailer, great post showing what a POS the stab n jab type connectors are. Light loads ok.
rhagfo wrote:
Safest would be RV Comfort Systems “Cheap Heat” electric add on furnace element. We installed before going full time works great. Purchase is not too cheap, but heats basement.
2oldman wrote:Curly2001 wrote:Not even close. From my research, blankets are under 200w.
It even makes me think that electric blankets could cause the same problems with their current draw.
