Curly2001
Dec 19, 2020Explorer II
Electric space heaters
Just curious if anyone has a good safe electric heater to use to heat a 30' fifth wheel overnight? Would like to supplement the propane furnace on colder nights.
Thanks,
Curly
Thanks,
Curly
Curly2001 wrote:
Thanks everyone for your input. I think I need to look at the wiring in the trailer to make sure the boxes are decent. It even makes me think that electric blankets could cause the same problems with their current draw.
Curly
rhagfo wrote:Yeah.. I tend to stay away from those places. :)
40 degrees is cold we get down to the mid-teens at times.
2oldman wrote:theoldwizard1 wrote:They do, as heat rises. My heater keeps my feet nice and toasty on the next to lowest setting even on the coldest nights. I'm not talking pianotuna cold, but 40° or lower.
Also, heated mattress pads work much better than heated blankets,
Cummins12V98 wrote:rhagfo wrote:
Safest would be RV Comfort Systems “Cheap Heat” electric add on furnace element. We installed before going full time works great. Purchase is not too cheap, but heats basement.
YEP, I got tired of tripping over and buying new space heaters. When we ordered our 16 Mobile Suites I had Rolling Retreats install ours. NOT "CHEAP" but some of the best money I have spent!!!
When hooked to shore power and the Park pays for the power WHY burn your propane???
We full time with it now for 5.5 years. I did have a control board go bad out of warranty and the company owner did me a solid, sold it to me cheap and shipped overnight. Only person I have heard of with that or any other issue.
As you mentioned it does heat the basement where a lot of the plumbing is located.
Toggle switch from propane to electric back and forth as needed.
coolmom42 wrote:
On a ceramic type heater, with a fan and screen in front of the heater bars, the surface is not hot enough to burn someone who touches it. Possibly a little uncomfortably warm, but not enough to burn. And like I said, check the tip-over protection. Most use a simple pressure switch on the bottom.
coolmom42 wrote:Bert the Welder wrote:
I'm interested in what type of heater you guys are running that has heated/melted your extension cords? Or what gauge cords you're using?
As for the OP. I look at my best bet being on a "bigger" name in the game as being "safer". Though I have little more than faith in that thinking. Howell, Sunbeam, Noma, Panasonic. Dyson if you like paying triple for the Gucci factor.
The overheating is not generally directly due to the heater load, but to poor connections with extension cords and plug strips, and the internal connections in the plug strips. Those connectors create hot points.
I've never found the wiring, plug, or outlet to be hot, during or after using a heater. Like I said, I just use the inexpensive little cube heaters. They are generally 1500 watts, which translates to 13.6 amps at 110V. So your circuit needs to be capable of handling that.
The only time I've ever tripped a breaker in a RV was when a heater kicked on while I was using a hairdryer. No big deal, unplug the heater and reset the breaker.
