the_bear_II
May 31, 2013Explorer
Yes They probably are equipped with over heat protection - self restoring circuit breakers or relays.
You may want to check your batteries to make sure you have a full charge and good connections. Bad connection and/or low voltage will cause the jacks to over heat.
