Old-Biscuit
May 31, 2013Explorer III
Good advice on checking batteries ^^^^^^
Also...........manually crank them down/up couple cycles and spray dry graphite lube on worm gear & drive. (Graphite Lube goes on wet then dries and will not attract dirt)
While manually cranking.check for any binding.
Easy movement, lubed up and full charged batteries they should work like new :B
