Old-Biscuit
May 31, 2013Explorer III
Have you gotten down under the rig and looked at them?
Might only be 9 months old to you....could be much older depending on when frame was built, stab jacks installed, how long frame sat around, build time, didn't get lubed etc.
'New' should work well like new but that's not always the case.
Check them out.........rusted, dry, dirty, binding etc.
Check motor amp draw/voltage under load. Motor could be the problem.
