hogbobExplorerFeb 25, 2015Electric stepHello, My electric step will not stay out in the "off" position. It goes in and out as the door opens and closes. But the step only stays in instead of out when the switch is off Thank you for an...Show More
MrWizardModeratorFeb 25, 2015try thisafter engine is offdoor switch onopen door let step go all the way outthen close door and let it retractrepeat again.. open then closenow on the third time open door..after step goes out and stopsturn off switchmy step has a replacement controller .. sometime before we got the RVand this is the procedure i use to keep our step outif this does not work for you, you have a bad controller or something is wired wrong,
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
