Hello, My electric step will not stay out in the "off" position. It goes in and out as the door opens and closes. But the step only stays in instead of out when the switch is off Thank you for an...
Leave the switch in the On position- Kwikee changed the switch operation, it is now an override switch, and in the on position, overrides the door switch. From the Kwikee FAQ (#2).
I'm assuming the door switch does operate like it should- door open, step extends, etc.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
