dougrainer
Sep 09, 2013Nomad
This is from the kwikee manual and explains why some think the step could cause a draw. It cannot if functioning to specs. Doug
If the power wire to the step is disconnected
from its source and reconnected,
a spark is common. This is caused by the
momentary charging of the control unit
and does not necessarily indicate the
system is staying on, which would cause
a drain on the battery. If battery drain is
suspected, observe the understep light (if
so equipped) while the step is extending.
The power switch must be on for the
understep light to operate.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Aug 01, 2013
