MrWizard
Nov 15, 2014Moderator
reason for the low wattage ?
overloaded circuit OR want to use existing inverter
the first is easy turn something off for a few minutes
the second.. maybe use a buck transformer between the toaster and the inverter supplied outlet..knock down the voltage 10~20% knock down the wattage, toasters are resistive heat..reduce the voltage and the power load goes down
that or a bigger inverter
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
